Concerned about block joint quality?
Tips, tricks and information on how to spot rogue and cowboy builders and also a platform for you to post and warn others of cowboy builders you may have encountered and help to spread the word of their dodgy dealings
Razza30
by Razza30 » Wed Mar 17, 2021 7:33 pm
Re: Concerned about block joint quality?
by stoneyboy » Thu Mar 18, 2021 10:00 pm
Hi razza30
If this is a solid wall it will not really matter. If it is the internal skin of a cavity wall and it is going to be dry lined it will probably lead to cold walls.
It is currently Thu Nov 21, 2024 1:48 pm
