UPVC DOORS
Housediy
UPVC DOORS
by Housediy » Thu Mar 18, 2021 12:20 pm
Please help,
I have been trying to stop the draft from my Uvpc double doors on the south facing garden. It's really windy on the back and so i can't help but get drafts because of the doors.
I have tried new rubber strip gaskets, adding foam strips on top of the gaskets to seal the evident gap and even tried adjusting the hinges... Its still there... The gap and draft... Any ideas please?
Thank you
Re: UPVC DOORS
by stoneyboy » Sat Mar 20, 2021 12:01 am
Hi housediy
Always a problem getting the right seals with older doors.
Try using stormguard brush nylon adhesive seal for garage doors but clean the surface where it will be stuck with an aggressive solvent eg cellulose thinners before you try to stick it in place.
Housediy
Re: UPVC DOORS
by Housediy » Thu Mar 25, 2021 4:44 pm
The 3rd picture shows the screw i turned to alter the compression. it appears that the centre bit which attaches to the other door there is slight give...maybe from temperature changes maybe?
hope you can help
thanks guys
ian
It is currently Thu Nov 21, 2024 7:37 pm
