Missing Earth When Testing Plug Socket in Summer House
Rachel29
by Rachel29 » Thu Mar 18, 2021 12:40 pm
Hello,
I have electric running from my boiler fused box which has a 3amp fuse into my summer house. When I have used a socket tester the plug socket in summer house is saying a missing earth. I have tried all sockets in the house, these are all ok, I have double checked the boiler fused box and socket in summer house and earth is present. What else can be the problem please?
Re: Missing Earth When Testing Plug Socket in Summer House
by Mr White » Thu Mar 18, 2021 5:21 pm
To clarify.
Your socket tester is saying at one particular socket there is no earth, but on all other sockets there is an earth ?
If this is so then there is no working earth at the socket. It could be a loose connection or a broken wire.
You could switch the mains off and remove the socket and investigate.
Rachel29
by Rachel29 » Thu Mar 18, 2021 6:05 pm
Yes that's right and I have done all this but everything looks OK. I have now put a earth cable from the socket to a copper pipe and the tester says its ok.
by Mr White » Fri Mar 19, 2021 8:07 pm
Just because something works does not mean it is safe. What it can not say is, it is dangerous, and potentially lethal.
It is currently Fri Jan 10, 2025 4:05 pm
