Best lights for illuminating retaining wall steps
Random90
by Random90 » Fri Mar 26, 2021 4:25 pm
Can anyone give me advice on the best light to use to illuminate step in a retaining wall, I've read brick lights usually are not very durable?
Re: Best lights for illuminating retaining wall steps
by Mr White » Sat Mar 27, 2021 4:43 pm
If you get 10 replies no two will be the same since this is an opinion question, and since everyone has a different opinion..........
I would say the main "Problem" with external recessed lights is that of water ingress.
This can be caused by using a cheap fitting, bad installation, damage (Accidental or otherwise) or a combination.
If you are going for the 12v option I suggested in your last post then there are quite a few options of sealed LED illuminated light fittings. These usually have a "fly lead" that you would need to pass through the wall and make connections in a weatherproof enclosure.
It is currently Sun Jan 05, 2025 4:59 am
