Cold tap in upstairs bathroom flow problem
pete1412009
by pete1412009 » Sat Mar 27, 2021 8:54 pm
Hi all,
I'm having an issue with the cold tap in my upstairs bathroom. There is barely a trickle of water coming out, while the hot water tap is running fine. I'm not having any problems with any other cold taps in my house.
A Google search suggests that there may be an airlock in the system.
I have attached a picture of the type of tap that I have.
Is there anything I can do to try and rectify this issue myself before getting a plumber involved? I am a total novice when it comes to these things.
Many thanks in advance!
Re: Cold tap in upstairs bathroom flow problem
by stoneyboy » Sun Mar 28, 2021 11:55 pm
Hi Pete1412009
Easiest way to clear the problem if it is an airlock is to use a wet vac to suck out of the tap when the cold is on full.
It is currently Thu Nov 21, 2024 1:54 pm
