Toilet Cistern Lever for Twyfords Jupiter toilet
adina66
by adina66 » Thu Apr 01, 2021 3:18 pm
Hi All, the toilet lever on my Twyfords Jupiter toilet has broken. It looks like its been eaten away by limescale.
It's a one piece side fitting lever and pivots on a plastic fulcrum bolted to the inside of the cistern.
I have bought a replacement lever, originals are no longer available, which looks like it should do the job. But I have a problem. The original bolt which passes through from the outside of the cistern is too short to be bolted to the new lever. Also, I cannot remove the old bolt. It might have been put in with some tile cement or other bonding agent.
Any ideas on how to get that bolt out. I haven' t tried a hammer or mole grips yet for fear of cracking/breaking the system.
Thanks, Adina.
Re: Toilet Cistern Lever for Twyfords Jupiter toilet
by stoneyboy » Fri Apr 02, 2021 10:09 pm
Hi adina66
Try using a hot air gun to soften the glue.
It is currently Mon Dec 23, 2024 11:07 am
