Making hole in false chimney breast bigger
Dulapeep
by Dulapeep » Mon Apr 05, 2021 12:32 pm
We want to make this hole taller to fit in a cast iron fireplace. The hole is boxed in with wood and I don't know what false chimney breasts are normally made of, can we just remove the wood and chip away at whatever is there?
Re: Making hole in false chimney breast bigger
by stoneyboy » Tue Apr 06, 2021 9:56 pm
Hi dulapeep
You can remove the ply liner - this is not strong enough to have any structural purpose. You will probably find a piece of angle iron across the top of the opening but there could also be a brick arch forming the top support. Suggest you hack off the plaster above the fireplace so you can see and decide how to proceed.
It is currently Sat Nov 23, 2024 1:15 pm
