Cost of emergency call-out to replace outside
CharlesLawson73
by CharlesLawson73 » Wed Apr 14, 2021 4:07 pm
Could someone give me an estimate cost for an emergency plumber call-out to replace an outside tap. My outside tap was gushing water from the check value with must have been blasted down the drain. I did not have an replacement tap. So I 'phoned an emergency plumber. He came out turned off the water; provided me with a replacement tap and fitted it.
Re: Cost of emergency call-out to replace outside
by stoneyboy » Thu Apr 15, 2021 10:37 pm
Hi charleslawson73
The cost of supply and fit a replacement outside tap as emergency would probably be £100-£150.... unless you live in London then the sky’s the limit.
It is currently Mon Dec 23, 2024 11:21 am
