Hi all. We are in the process of renovating our home and I have been pondering how to plumb in the rads on the ground floor as the floors are concrete. Firstly the system is a boiler only system, open vented with how water tank in airing cupboard. Up stairs there are four rads and a heated towel rail which I have plumbed with 15mm copper using standard feed and return pipes. Eventually on the ground floor we plan five rads.
I had assumed that I would 'simply' be chasing out the concrete floor at ground level and either install copper pipes (in ducts or wrapped to protect them for the concrete) or plastic to plumb the downstairs rads. But then on the internet I discovered manifolds and microbore. Running this from the ceiling and chasing into walls would be much easier. So my questions are...
1: Is it fine to have 15mm copper feed and return system for first floor rads and manifold and 10mm microbore for ground floor rads?
2: Assuming the answer is 'yes' can I put the manifolds onto the 15mm copper pipes are already installed to feed the ground floor rads or do I need to tee off the 22mm boiler feed and returns and place them on those?
3: If I go for the design above are there any percautions or design considerations I need to take into account? (I'm thinking balancing really, different flow rates??)
4: Micro bore pipes in walls concern me a little. Do I/should I install in metal conduit to add some protection or am I being paranoid?
All advice very much appreciated. Bing
