Damp proof a concrete step for tiling over?
blacky165
by blacky165 » Sun May 02, 2021 2:42 pm
Novice here, hopefully someone can help me. I'll shortly be re-tiling the kitchen floor. The existing floor is quarry tiles, all secure, no damp, pretty uneven, but not bad. I was going to use a self leveling compound over the top and selectively remove the most uneven quarry tiles (only 2 or 3 tiles). However I have an area of concern by the back door. The back door sits on a 30cm wide concrete sill that brings a little moisture/damp into the kitchen. The damp doesn't spread beyond this concrete sill, but I will be tiling over this sill as it protrudes into the kitchen approx. 20cm. The sill is at the same level as the existing quarry tiles.
Can I just paint the concrete sill with a damp proof paint (black jack paint?), and then use self leveling compound over this paint?
Algorithm
Re: Damp proof a concrete step for tiling over?
by Algorithm » Mon May 03, 2021 9:55 am
Hello. The best thing for that kind of work is SBR. To be exact it calls CEMENTONE SBR ADMIXTURE. Cover sill twice and it will be perfect.
blacky165
by blacky165 » Tue May 04, 2021 2:39 pm
Perfect! Not heard of this product before. But I've googled it, and it appears to be just what I need. Thank you!
It is currently Thu Jan 30, 2025 11:19 pm
