What is the best way to clean and paint this bit above a bay window?
apacheDIYman
by apacheDIYman » Wed May 12, 2021 11:03 pm
Whats the piece above the window called and is there a specific type of outdoor paint I should use?
Re: What is the best way to clean and paint this bit above a bay window?
by stoneyboy » Sat May 15, 2021 10:46 pm
Hi apachediyman
Assuming you are referring to the roof part it’s a splayed bay window roof. How you treat it will depend on whether it is lead - scrape the roof lightly and see if it comes up shiny metal. If it is lead best to just wash down but you should redo the short length of pointing which is missing on the flashing.
If it is not lead it will probably be an off-the-shelf grp roof - find out who the manufacturer is and ask what they suggest.
apacheDIYman
by apacheDIYman » Sun May 16, 2021 12:05 pm
Hi thanks for this info, so I realised I could use patination oil for the lead flashing, but what is the best grey/dark grey paint type to use on the bottom curvy bit just above the window itself? I am not sure what material it is. Maybe a multi surface paint will work?
by stoneyboy » Tue May 18, 2021 10:30 pm
Hi apacheman
Suggest you try to find a marine paint used to paint grp boat hulls.
Andy3746
by Andy3746 » Sat May 14, 2022 5:56 pm
Hi apacheDIYman, your bay window roof is just like ours and I have the same question as your goodself last year!
May I ask please, did you find a good way to clean/paint to improve the appearance?
Any hints and tips very much appreciated, kind regards
Andy
It is currently Thu Nov 21, 2024 7:35 pm
