How to clean corroded rusty bathtub waste hole
FLilley
by FLilley » Sat May 15, 2021 7:48 pm
I'm replacing an enamel bathtub waste drain and have removed the old plughole, but it is quite corroded/rusty where the old black rubber washer was seated below the chrome plughole. What is the best way to clean this up before fitting a new waste? Scrape with screwdriver? WD40? Some sort of commercial rust remover? If so what type? Any advice greatly appreciated.
Re: How to clean corroded rusty bathtub waste hole
by stoneyboy » Sun May 16, 2021 10:57 pm
Hi flilley,
Do not use any form of chemical cleaner, this will etch the enamel surface and ruin it. Suggest you try a scouring powder cleaner but you may find the rust has deeply stained the enamel.
FLilley
by FLilley » Mon May 17, 2021 12:31 am
Many thanks I'll give it a go...
It is currently Wed Dec 04, 2024 6:10 am
