Old shower pump replaced but new one not working
Lpen
by Lpen » Sat Jun 19, 2021 7:27 pm
Our old shower pump was getting weaker and eventually stopped working and gave off a burning smell. We have replaced the shower pump and the new pump won’t work. It makes a short noise when switched on but does not increase the shower flow. Can anyone suggest what might be the issue and help us resolve it? Have contacted a lot of plumbers but everyone seems very busy.
Re: Old shower pump replaced but new one not working
by stoneyboy » Sun Jun 20, 2021 9:48 pm
Hi lpen
You do not give very much detail about the installation but if you have replaced old pump with a new one with the same spec then the most likely problem will be that you have an air lock in the pump. Clear this and the pump may work.
It is currently Fri Jan 10, 2025 12:54 pm
