Footing depth for concrete block retaining wall
Justaddwater
by Justaddwater » Thu Jul 08, 2021 10:54 pm
I'm looking to build a retaining wall, probably in standard concrete blocks laid flat. It will be about 7m long and minimum of 1.3m high and will be filled behind with hardcore.
The ground I think is chalk, but my questions are:-
1. Will a 9" wall be ok without piers?
2. Am I better off making the wall wider by making it a cavity, or using hollow 'H' blocks?
3. What Depth and width should the footing be?
Re: Footing depth for concrete block retaining wall
by stoneyboy » Fri Jul 09, 2021 10:06 pm
Hi justaddwater
Laying solid concrete blocks flat will be fine but use a strong mortar mix 4 or 5 to 1. Probably worth adding a pier at either end.
You will need 18” wide foundations but the depth will depend on ground conditions - you will have to dig deep enough to reach a very firm base ie a spade will not go in very far.
Justaddwater
by Justaddwater » Sat Jul 10, 2021 12:33 am
Thanks Stoneyboy.
Nice straightforward answer. I am just a bit concerned about the amount of weight on the footing with just the height of blocks on top
by stoneyboy » Sun Jul 11, 2021 9:38 pm
Hi justaddwater
In terms of the depth of the foundation itself you will need to make them at least 200mm, you could add rebar if you do not get down to a solid base.
It is currently Mon Dec 02, 2024 10:58 am
