LED lighting flickering, still on but very dim
Poire
by Poire » Fri Jul 09, 2021 4:38 pm
I installed an LED ceiling lamp a year or two ago and it went out this week. Something is not quite right as it flickered out and then remained dead, although a close look shows that the web of LED lamps are all on but very dim. For a day the lamp 'fixed itself' but has now gone back to being off or at best flickering when I activate the switch. Does it need to be replaced or adjusted? I tried tightening all the connections in case something was loose.
Re: LED lighting flickering, still on but very dim
by Mr White » Sat Jul 10, 2021 9:14 pm
If a lamp fails, the first thing I would try is a new lamp.
It is currently Fri Jan 10, 2025 11:58 am
