What to use to fill hole in plasterboard after pipe repair?
Elliot91
by Elliot91 » Sun Jul 18, 2021 8:14 pm
Hi everyone,
I drilled into a central heating pipe while putting some curtains up.
I repaired the hole by putting this in like connector in.
What is the best way / filler to
repair the plasterboard?
Re: What to use to fill hole in plasterboard after pipe repair?
by stoneyboy » Mon Jul 19, 2021 11:28 pm
Hi elliot91
Chafer the edges of the hole, cut a piece of plasterboard to loosely fit, glue the panel in place so it is below the surrounding boards. When set plaster over the blanked off hole.
It is currently Mon Dec 02, 2024 11:37 am
