Joining old and new foundations
Souljim
by Souljim » Tue Jul 27, 2021 9:34 pm
Hi all,
I’m taking down an old conservatory and extending it out to create a larger single storey extension. I’ve got some 25mm x 600mm steel bar to tie the new footings into the existing foundations and had a few questions. What size drill bit do I need? Is 26mm okay or do I need it to be slightly bigger (say 28mm) for the epoxy resin. I don’t want to buy an expensive resin gun to use it once either and I know you can buy some epoxy resins in a syringe that pre-mixes it. Any idea on which one’s best? Thanks
Re: Joining old and new foundations
by stoneyboy » Thu Jul 29, 2021 9:47 pm
Hi souljim
Probably better to go for the 28 to give a good surround of resin. Go for pure epoxy type.
It is unlikely that conservatory foundations will be adequate for a SS extension so you may have to replace them anyway.
It is currently Sun Nov 24, 2024 5:02 am
