10amp 2 pin connector on a 3amp hedge trimmer
Mac_Wood
by Mac_Wood » Tue Aug 03, 2021 11:52 am
Hi all,
I have a hedge trimmer which has suffered a few cable cuts. In the past I've reconnected the cables using a chocbox weatherproofed with insulating tape. I decided to remove the affected cable and re-join using a 10 amp 2 pin connector. Perhaps it is my electrical abilities that have let me down, as the trimmer won't start up, or perhaps the 2 pin connector was a non-starter, and I therefore need to replace the whole length of cable and discard the connector. Please advise me as to the best course of action. Thanks
Re: 10amp 2 pin connector on a 3amp hedge trimmer
by stoneyboy » Thu Aug 05, 2021 9:04 pm
Hi mac_wood.
Assuming the original cable was 2 core there’s not really much that can be wrong. Check your connections and the continuity of all cables.
It is currently Fri Jan 10, 2025 12:09 pm
