installing a 200x200 gate post with Hanson Fast Set PostFix . Will it hold ?
oneoone
by oneoone » Thu Aug 12, 2021 5:38 pm
I'm planning to install a gate post and wanted to know if Hanson Fast Set PostFix would do the job as I can only fine people using it to install small or at most 100x100 fence posts.
Thank you for any help and advice
Re: installing a 200x200 gate post with Hanson Fast Set PostFix . Will it hold ?
by stoneyboy » Fri Aug 13, 2021 10:20 pm
Hi oneoone
Setting in postfix will be ok if: the hole is deep enough; if the hole is large enough; if the surrounding ground is firm enough; if you are not going to hang a field gate on it. If you end up using a 100x100 post this will bend with the weight of the gate.
It is currently Wed Dec 04, 2024 8:37 am
