by ericmark »
Sun Aug 22, 2021 1:40 pm
I think the X is really [attachment=0]Dimmer-termial-sign.jpg[/attachment] and it is output to lamps, so in to L out from [attachment=0]Dimmer-termial-sign.jpg[/attachment] normally we only have Com and L1 or L1 and L2 with an on/off switch, we may get Com L1 and L2 on a two way switch but the dimmer is not two way.
You can get two way dimmer switches they come as a pair you can't mix and match with other makes.
Electronic switches without a neutral have to allow a small current through the switch when off, so some bulb will flash when switched off with a electronic switch without a neutral, also some bulbs will shimmer when switches on, and only way to find out is try the bulb, so using smart bulbs is often the easiest way.
- Dimmer-termial-sign.jpg (28.28 KiB) Viewed 2621 times
