Replace the kitchen tap question with new tap with 2 flexi hoses
greglu
by greglu » Tue Aug 31, 2021 6:41 pm
photos
photos
I have a 5-year old kitchen tap which is dripping badly now. I searched at B&Q website and found a desired kitchen tap to replace the current. But it appears to me that the new tap involves 2 flexible hoses, e.g. 1 hot and 1 cold water. My current tap has two rigid pipes connected to it, but I am not sure if it has disguised soft hoses inside (as I cannot see it).
May I ask if any welding job is needed? Or I may have a go with a box spanner. Thank you!
Re: Replace the kitchen tap question with new tap with 2 flexi hoses
by stoneyboy » Wed Sep 01, 2021 10:36 pm
Hi greglu
Turn off the isolating valves and undo the top joint, if you are lucky the flexibles on the new tap will just screw in place.
It is currently Mon Dec 02, 2024 6:42 pm
