plastering breeze blocks
jezlings2
by jezlings2 » Thu Oct 04, 2007 9:55 pm
Can you plaster straight onto breeze blocks or do you have to plaster board first?
LCL
by LCL » Fri Oct 05, 2007 7:56 pm
jezlings2
Are your blocks new? If so they are likely to be concrete or insulating blocks (technical point).
Answer to your question:
1. You can dot and dab. This is plasterboard bonded to the wall on gypsum dabs and skim finish. (make the walls sound hollow and is used a lot in new housing). Quicker to apply and less water, therefore less shinkage afterwards.
2. A two coat plaster finish. Something like Thistle Undercoat, bonding or renovation plaster as your base coat (correctly applied - not to a bone dry wall) and finish with a thistle multi finish.
Hope this helps
LCL
jezlings2
by jezlings2 » Sun Oct 07, 2007 8:47 am
Many thanks mate was great help.
It is currently Sat Nov 23, 2024 8:31 pm
