External wall and tiling on wall or on Insulate board
Mightymiller
by Mightymiller » Mon Sep 20, 2021 11:23 am
I am renovating the bathroom. When I remove the old tiles all the plaster is also coming away. Can I fit the new Bathroom Wall Panels direct to the external cavity wall or do I need to fit some insulation board first? Or even worse - replaster.
Re: External wall and tiling on wall or on Insulate board
by stoneyboy » Tue Sep 21, 2021 10:51 pm
Hi mightymiller
Whether you insulate first or fit wall panels direct to the wall you will need a contiguous background so plastering will be required. As an alternative you could batten the walls, packing where plaster is missing, insulate between the battens and fix your boards to the battens.
Mightymiller
by Mightymiller » Wed Sep 22, 2021 10:09 am
Thanks for your response Stoneyboy. How about if I remove all the old plaster and replace with plasterboard then fit the wall panels direct to Plasterboard?
by stoneyboy » Wed Sep 22, 2021 10:08 pm
Hi mightymiller
Yes you can do that but use tile on board in the wet areas.
It is currently Sun Dec 22, 2024 6:11 am
