Isolation valve totally seized up before replacing sink tap washer
Phattanglo
by Phattanglo » Fri Sep 24, 2021 1:33 pm
Just located an isolation valve before replacing a sink tap washer and the valve is completely seized.
I'm struggling to find a replacement as it appears to be 22mm at one end and 15mm at the other and I can't find one on t'internet.
Should this be a common size? The pipework isn't all that old so I'm assuming it's metric.
Re: Isolation valve
by stoneyboy » Sat Sep 25, 2021 10:42 pm
Hi phattanglo
Sounds like you have a washing machine valve fitted.
It is currently Fri Nov 29, 2024 3:47 pm
