Raising an existing concrete floor that's lower than rest of house
Mistyderek
by Mistyderek » Fri Oct 01, 2021 10:24 pm
I am renovating a house . There is an extension which has a 3m by 4m floor approx 200 mm lower than the rest of the house. It is a concrete slab topped with 25 mm of polystyrene and chipboard.
I am thinking about how to raise it 200 mm reasonably efficiently...Possible options [1] celotex then screed [2] two layers of celotex then chipboard and [3] 100mm kingspan then aircrete blocks laid flat with sand /cement brushed into joins..sort of like block and beam...what do people think?
Re: Raising an existing concrete floor that's lower than rest of house
by stoneyboy » Sat Oct 02, 2021 11:51 pm
Hi Mistyderek,
Suspect it will come down to cost and convenience. I would choose 180mm expanded polystyrene topped with 22mm t&g chipboard sheets.
Mistyderek
by Mistyderek » Sun Oct 03, 2021 8:25 pm
Yep, I think so as long as the BCO will live with it.
by stoneyboy » Mon Oct 04, 2021 3:14 pm
Hi mistyderek.
You may have to incorporate a DPM if there is not one.
Regards S.
It is currently Thu Oct 31, 2024 7:30 pm
