0 Bar on Glow Worm boiler - yellow lever not working to top up?
Vanderlust
by Vanderlust » Sat Oct 02, 2021 7:28 am
Old boiler broke earlier in the year and landlord had a new one installed.I can't really remember how I topped up before. Tried the yellow lever but nothing happens. Youtube videos on it say you need to release two levers first, but the model looks different to mine.
https://ibb.co/fG0gYkp
https://ibb.co/SJhyPVq
https://ibb.co/6sCLm3h
https://ibb.co/HXGtfzZ
Do you guys who if I'm supposed to be loosening another lever, or maybe open the panel and do something? Thought I'd try here before trying the landlord, he usually takes his time replying and it's probably something super simple.
Vanderlust
Re: 0 Bar on Glow Worm boiler - yellow lever not working to top up?
by Vanderlust » Sat Oct 02, 2021 7:50 am
Oops, well since posting this I see it's nothing to do with the yellow valve!
There are three black valves under the boiler and this video looks similar to mine:
https://www.youtube.com/watch?v=LX7R_WAOxFw
When I use the screwdriver to turn clockwise the two right hand side valves though nothing happens!
Vanderlust
by Vanderlust » Sat Oct 02, 2021 7:59 am
Found a black little valve tucked under what I think is called the filling loop. Put the other valves back to the way they were. It worked to fill the boiler pressure I think as the front panel changed from pressure to temperature (annoyingly as I couldn't see what bar it was).
It's now in some sort of startup sequence where it flashes from 0.9 to 1.2bar. How long should this last for anyone know?
It is currently Thu Nov 28, 2024 5:39 pm
