Confusing radiator valves and radiator that won't work
scottwalkerwrites
by scottwalkerwrites » Sat Oct 02, 2021 10:46 am
Hi I've recently moved into a house and can't work out how to get this radiator to work.
It looks like traditional TRVs - right side is a brushed gold tap that turns freely and has a pin-type cube fitting in the middle of it which also unscrews.
On the left there is what I think is an outlet valve. It doesn't turn.
But I can't get the thing to heat up. Any ideas?
Many thanks.
Stilson24
Re: Confusing radiator valves and radiator that won't work
by Stilson24 » Thu Nov 11, 2021 5:06 pm
I think the one on the left is just a cover, underneath the cover will be a 'lockshield ' valve spindle.
Wrap with tape and use a pair of grips to loosen.
Stilson24
by Stilson24 » Thu Nov 11, 2021 5:07 pm
It is currently Wed Jan 15, 2025 8:16 am
