Flat roof leak around log burner flue ...
kev100
by kev100 » Tue Oct 05, 2021 3:12 pm
Hello,
When the wind's in the right direction we get water leaking down on to the log burner itself.
Anyone got any suggestions on how best to seal up the roof/area around the flue (which dies get hot)?
Cheers,
Kev
Re: Flat roof leak around log burner flue ...
by stoneyboy » Thu Oct 07, 2021 10:04 pm
Hi kev100
It looks like there is daylight getting in around the flue on your internal picture. This needs addressing and suggest you use a heat resisting silicone seal to seal the gap.
kev100
by kev100 » Sat Oct 09, 2021 3:42 pm
Hi there, and thanks for the reply. The interior photo is somewhat misleading, and the highlight it shows isn't daylight coming in through the roof. I've adjusted the photo so you can see it a bit more clearly, and put an arrow where the water drips down from.
I'm keen to hear any recommendations re the heat resistant sealant ...
Cheers,
Kev.
by stoneyboy » Sat Oct 09, 2021 10:42 pm
Hi kev100
It looks like you have a twin wall flue outside which becomes a single skin flue inside the building. Try using plumbers flue silicone on the lower flue joints outside. If this doesn’t solve the problem you will have to investigate the single to twin wall junction and see if this has been properly joined. There is a remote possibility that the china mans hat on the top of the flue is not big enough.
kev100
by kev100 » Wed Oct 13, 2021 9:48 am
Okay. Thanks for the tip.
Kev
It is currently Tue Dec 03, 2024 10:56 am
