Connecting 2-1 toilet sink combo to single water supply
Twosons53
by Twosons53 » Sat Oct 16, 2021 11:10 am
I have a single cold water suppy
15mm female flexi connection from tap
and 15mm cystern inlet
The toilet - https://www.plumbworld.co.uk/documents/ ... -guide.pdf
I can connect the sink easily enough from water supply pipe isolating flexi to tee joint to sink flexi, but the tee joint to the cistern connection doesnt seem to exist? i was looking for a 15mm flexi hose with female connections at both ends?
any ideas
Re: Connecting 2-1 toilet sink combo to single water supply
by stoneyboy » Sun Oct 17, 2021 10:23 pm
Hi twosons53
If I have understood your post correctly a tap flexible connector should do what you want. Look for 15mm copper to 1/2” bsp.
It is currently Mon Nov 25, 2024 8:02 am
