Replacing a light fitting....and earth is too short....HELP?
jellytots2007
by jellytots2007 » Fri Oct 05, 2007 12:41 pm
I am currently (well a friends boyfriend is for me) trying to replace one 3 plate spot light with another...but the current one doesn't use the earth wire...but the new one needs it....which wouldn't be a proplem apart from the wire has been cut v short.
Is there any way to extend it?????
BLAKEY1963
Re: Replacing a light fitting....and earth is too short....H
by BLAKEY1963 » Fri Oct 05, 2007 7:35 pm
[quote="jellytots2007"]I am currently (well a friends boyfriend is for me) trying to replace one 3 plate spot light with another...but the current one doesn't use the earth wire...but the new one needs it....which wouldn't be a proplem apart from the wire has been cut v short.
Is there any way to extend it?????[/quote]
JELLYTOTS
TRY A 5 AMP CONNECTOR BLOCK AND USE EARTH SLEEVING TO COVER EARTH WIRE. ISOLATE SUPPLY WHILE WORKING
BLAKEY1963
jellytots2007
by jellytots2007 » Mon Oct 08, 2007 4:44 pm
Thank you!
We will give that a go
It is currently Tue Jan 14, 2025 12:12 pm
