Heavy weight front door gone out of line
paulmcr
by paulmcr » Tue Oct 19, 2021 3:33 pm
I have a heavy front door (98cm wide). It has gone slightly out of line and now rubs when opening and closing (see attached picture of the door frame, this shows it has dropped slightly). I have tightened up the hinge screws yet it is still out of line.
Please advise, many thanks,
Paul
Re: Heavy weight front door gone out of line
by stoneyboy » Wed Oct 20, 2021 11:24 pm
Hi paulmcr
Open the door slightly and push hard on the edge towards the hinges. Get an assistant to look to see if there is any movement you will then know what needs tightening.
paulmcr
by paulmcr » Sat Oct 23, 2021 1:06 pm
Thanks, I will give that a go.
Paul
It is currently Sun Dec 22, 2024 5:46 am
