Dirty expansion tank water in loft
DIY_Chimp
by DIY_Chimp » Sun Oct 24, 2021 1:57 pm
The water in Our small expansion tank in the loft is quite dirty. Does it need to be cleaned or is it ok to leave it? Also, does it need to have a lid?
Re: Dirty expansion tank water in loft
by stoneyboy » Tue Oct 26, 2021 9:59 pm
Hi diy_chimp,
Header tanks are generally pretty dirty because of the rusty steel deposits from radiators. If the tank has a thick sediment in the bottom then yes clean it out.
It’s definitely worth having a lid on the tank even if it’s only a sheet of expanded polystyrene with a weight on it.
