Casement Windows
Jim.h
Casement Windows
by Jim.h » Tue Nov 02, 2021 11:21 am
Hi Guys, looking for some help here….. My house has top hung wooden casement windows over 30 years old but still keeping the cold out. The locking mechanism on some of the windows is seized solid and I can’t see a way to ease them off. The central handle in the centre of the lower frame operates a square drive and when the handle is rotated through 90 degrees locking bars emerge from the lower outside edges to lock the windows……..the mechanism are all stiff and some are seized…..is there a way to access the mechanism so that it can be repaired?
Re: Casement Windows
by stoneyboy » Thu Nov 04, 2021 9:57 pm
Hi Jim.h.
Basically no. Try removing the handles and use a longer bar to turn the mechanism. Once opened use something like wd40 to lubricate every moving part. Spray into any recess when is may get to the mechanism.
Jim.h
by Jim.h » Thu Nov 18, 2021 5:27 pm
The top hung wooden casement window is locked but the mechanism is not attached to the handle and can’t be manipulated. This is an old unit and the lock comprises a metal bar protruding either side of the lower frame. Just wondering if the window can be opened by removing some of the frame on the outside of the window allowing access to the locking bar
by stoneyboy » Thu Nov 18, 2021 7:20 pm
Hi Jim.h
Assuming you have a storm proof casement (where there is a flange on the outside of the casement) the only access will be through the handle hole. If you remove the handle you may be able to manoeuvre the locking yoke to release the side pins.
It is currently Wed Jan 15, 2025 10:15 am
