What type of bulb connector is this for outdoor floodlight?
Pandor
by Pandor » Sat Nov 06, 2021 3:53 pm
Hi all,
Need to change the outdoor floodlight bulb. Taken it out but a bit stumped as to what type of bulb connector it is. Anyone know?
Re: What type of bulb connector is this for outdoor floodlight?
by Mr White » Sat Nov 06, 2021 10:09 pm
What you have there is called a Compact Fluorescent Lamp. That one was designed with a right angled pin configuration so that it can be mounted sideways. (Normally they are vertical)
I doubt you will get one as CFL's are out currently out of favour, and need to be disposed of responsibly as they contain mercury.
Your lamp does not look too bad (It is not black at the ends) which implies it is the "switch gear" that is at fault, not the lamp. (The switch gear is inside the light fitting)
You really would be better off changing the complete floodlight to one that has LED's, not only will it be brighter, it will instantly illuminate and use less electricity.
It is currently Fri Jan 10, 2025 8:16 am
