How to fill huge hole in the ceiling
Jan Tramana
by Jan Tramana » Fri Nov 12, 2021 10:47 pm
So we have this massive hole (about 6 omch diameter) in the room ceiling going to the loft area, as we decided to get rid off the old air warmer system to heat the house and install a combi boiler.
What will be the best way to fill it? Is the expanding foam a good choice???
Winter is approaching and I feal that the heat is leaving the room towards the loft and the room never gets cozy enough.
Re: How to fill huge hole in the ceiling
by stoneyboy » Sat Nov 13, 2021 10:14 pm
Hi jan tramana,
No foam is not the answer, fit batten size strips of wood over the hole and screw in both ends, 2 strips should do. Cut a piece of plasterboard slightly small than the hole and screw this up, fill gaps with filla.
It is currently Mon Dec 02, 2024 1:59 pm
