Hi all,
Firstly, I have recently moved into a new property and have discovered two problems. These are:
1) I have spot lights " dimmer controlled" not low voltage, in my lounge and a flourscent light in the kitchen. When both the lounge and kitchen lights are lit all is ok, but when I switch OFF the flourscent in the kitchen, the spot lights flash once. They only flash when they are on full and not dimmed. What could the problem be and how could I cure it??.........
2) Also, could some one please explain what the difference is between, supplementary and equipotential bonding and how are they installed in the bathroom????. Which one applies to the bathroom? There is no sign of earth cables on any pipes in there. There is earthing on the gas and water pipes at the intake, will i still need earthing in the bathroom...
I am a confident diy person on most things except electricity, and help would be greatly appreciated????
Thanks in advance.........
