Insulating a loft that has been lined with plywood
glynholman
by glynholman » Sun Nov 28, 2021 6:04 pm
I have just bought a 1930s house which has a new roof which is less than 5 years old.
The loft has plywood screwed to the Inside of the rafters with no insulation between the plywood sheets and the black membrane.
This must help insulate I guess but my question is should I take them off or are they ok to leave,as I have never seen this before.
My intention is to lay another layer of the rolled insulation on the floor but not sure why plywood was screwed (5mm) to the inside of loft to the rafters
Appreciate a little guidance
Re: Insulating a loft that has been lined with plywood
by stoneyboy » Mon Nov 29, 2021 10:22 pm
Hi glynholman,
Leave the ply in place and increase the depth of insulation on the floor. The ply may have been added to protect the loft contents especially during a re-roof.
glynholman
by glynholman » Mon Nov 29, 2021 10:27 pm
Thank you for the reply, you’ve put my mind at rest
It is currently Thu Nov 21, 2024 7:30 pm
