Leaking low level,close coupled push button toilet flush
6 posts   •   Page 1 of 1
aleconner
by aleconner » Thu Dec 02, 2021 9:22 am
I have a low level, close coupled toilet with push button flush. I replaced the flushing unit and the inlet valve since it was constantly dribbling into the toilet causing the cistern to refill every few minutes. It is still happening with the new unit! I noticed that there was a "slider" on the unit with 5 positions (1-5) and it was at position 5. I don't know what this does but could this be the problem?
Re: Leaking low level,close coupled push button toilet flush
by stoneyboy » Fri Dec 03, 2021 11:48 pm
Hi aleconnor
The issue with your old flush unit was most likely to be a deformed/worn washer s]at the bottom of the flush plunger or debris stopping a proper seal being made.
If the new unit has been fitted correctly the only way water can be running into the pan is if the cistern is filling too much and overflowing through the flush unit. Try adjusting the fill valve.
The slider is to control the volume of the flush.
aleconner
by aleconner » Sat Dec 04, 2021 8:14 am
Hi Stoneyboy,
Thanks for that prompt reply. At a quick glance it doesn't seem to be overfilling but it will be a couple of days before I can have a good look. I'll let you know!
Regards
Aleconner
by stoneyboy » Sat Dec 04, 2021 10:47 pm
Hi aleconner,
Thanks for responding, there is always the possibility that you new flush unit is faulty. When water is running in the pan try pushing down the central plunger - if it stops the bottom seal is faulty.
aleconner
by aleconner » Tue Dec 07, 2021 11:30 am
Hi Stoneyboy,
All sorted. I took the flush unit off, cleaned the surfaces and fitted a new washer. Everything working OK.
Thanks for your input and regards.
Aleconner
by stoneyboy » Tue Dec 07, 2021 10:34 pm
Hi aleconner,
Thanks for letting us know.
It is currently Mon Dec 02, 2024 5:40 pm
