Cold water header tank in workshop
wadeydiyer
by wadeydiyer » Thu Dec 09, 2021 2:51 pm
I have a workshop that was built over 30 years ago with original washbasin/pedestal and close coupled (plastic cistern ) toilet. Only cold water as hot water is fed by a small electric water heater.
Rising main comes into property and goes to one cold tap then continues to a header tank above the cloakroom which then feed a cold tap in the same sink and the toilet cold water feed.....
Looking to replace with the infamous 'Sink in a box' and 'Toilet in a box' from the good ol' boys at City Plumbing. Can I do away with the header tank/ballcock system and, more importantly, why was it there!!
Re: Cold water header tank in workshop
by stoneyboy » Fri Dec 10, 2021 10:04 pm
Hi wadeydiyer,
Best suggestion is that when built the water supply was not reliable so a tank was added so there was always water available. If you have consistent pressure and flow you can take the tank fed part out of your system.
It is currently Mon Dec 02, 2024 6:40 pm
