Ceiling rafter support for two-person hanging bed
mhpage
by mhpage » Fri Dec 10, 2021 2:50 pm
I want to hang a two-person bed from the ceiling rafters (see image). I think one rafter should be able to support this weight, but just to be safe, I'd like to distribute the weight over two rafters. I don't want to use rope because I assume pulling the rafters toward each other would be bad. My plan is to put a rod of some sort between the two and hang the bed from the middle of the rod. Better suggestions? And if not, what material rod do you recommend?
It is currently Sun Dec 22, 2024 1:06 am
