Wiring old Drayton thermostat to wireless?
david howells
by david howells » Tue Dec 21, 2021 3:25 pm
hi just like to know is it possible to wire a old drayton to wireless mode
Re: Wiring old Drayton thermostat to wireless?
by ericmark » Tue Dec 21, 2021 9:26 pm
You would need to verify, but it seems likely the old thermostat is standard low voltage (230 volt) so an electronic type can likely replace it.
The thermostat you show comes in many versions, including under floor heating which often has remote sensors, when you say wireless what do you mean.
david howells
by david howells » Wed Dec 22, 2021 7:17 am
its a drayton just like to know where the wire go on a
BEOK BOT-313 WiFi Programmable Boiler Thermostat, Alexa & Google Home compatible i know the negative and possitive easy its the briddge and othe one not a clue or even if it would work ps thanks ffor your reply
by ericmark » Sun Dec 26, 2021 12:47 pm
Even copy and pasting you pictures into paint shop I can't read the words fully, but seems likely
Blue to N
Brown to L with link to Com
Black to Open
Green/Yellow make safe, connect to back box if there is a terminal.
5 and 6 not used.
