by BLAKEY1963 »
Sun Oct 07, 2007 4:01 pm
[quote="rangadeva"]While changing the lightings one5Amp fuse blown off and now I am left without any light downstars. I changed the burned rewirable fuse many times but it did not help. Still I dont have light. Anybody knows what is the reason? Where is the problem? Why still the is no electicity?
Michael[/quote]
RANGADEVA
IT IS POSSIBLE THAT CONDUCTORS AT THE POINT WHERE U CHANGED YOUR LIGHT FITTING HAVE BEEN SHORT CIRCUITED
ACCIDENTLY, BY TRAPPING OR INCORRECT CONNECTION OF CONDUCTORS.
WITH SUPPLY ISOLATED , CHECK THAT YOU HAVE CONNECTED NEW FITTING, THE SAME AS THE OLD FITTING WITH THE WIRES IN THE CORRECT PLACES.
U CAN LOOK AT DOC PROJECTS ABOUT LIGHTING ( SHOWS WIRING DIAGRAMS ) TO VERIFY YOUR CONNECTIONS.
OTHERWISE U MIGHT NEED TO GET AN EXPERT IN
BLAKEY1963
