3 red wires 1 black when replacing light fitting
steve_since_85
by steve_since_85 » Tue Dec 28, 2021 5:47 pm
Evening all,
Can anybody shed any light (no put intended) on this.
I'm replacing a light fitting and I've come across 3 red wires, 1 black and 2 earths. I've fitted red/red and the single black into the blue but the light won't switch off and reading on similar issues it appears the single black wire may actually be the live, if this is the case, how can I find out which red is neutral and can I just block the other 2 wires off?
Thanks in advance
Steve
Re: 3 red wires 1 black when replacing light fitting
by Mr White » Wed Dec 29, 2021 9:49 am
To identify if a wire is live or not you need a multi meter or a two probe voltage indicator, proximity voltage indicators are known to be un reliable.
From your description it sounds like you are some wires missing, I would suggest you get an electrician in to check things for you.
An acknowledgement that you have read this post is always appreciated
It is currently Fri Jan 10, 2025 7:39 am
