what size header and spacings should I use?
arcon5
by arcon5 » Fri Jan 14, 2022 5:42 am
Just wondering what size header I should be using and what bolts and spacings for installing it.
The roof will be approx 10degrees spanning 3.1m and a width of 4.7m. The 4.7m header will be attached to a brick house wall and will be using 6x2 @ 400mm spacing attached to the header with hangers. So will attach the wall one side, will secure on to a timber ring beam on a conservatory the other side.
Deaf weight wise it will hold 6 ish sheets of HW Ply and either roofing sheets or shingles.
Thanks all.
Re: what size header and spacings should I use?
by stoneyboy » Sat Jan 15, 2022 10:37 pm
Hi arcon5,
You may as well use the same size as your rafters - 6x2.
Bolt spacing will be dictated by brick spacing so bolt into every 2nd brick at about 450mm spacing.
It is currently Mon Dec 02, 2024 11:01 am
