Broken chair joint epoxy repair?
fhkhf
by fhkhf » Mon Jan 31, 2022 5:57 pm
Got two dining chairs that have had a joint break off in very similar places. They’ve detached at the weld point…considering trying to fix it up with an adhesive / epoxy but not sure whether it will hold weight - what should I use?
I’ve had a look at JB Weld but I see comments online suggesting the tensile strength figure is overstated / optimistic!
Images linked below
The detached joint - https://ibb.co/5BFt0Nj
Snap of the weld where the joint broke off - https://ibb.co/NWT1LmY
Re: Broken chair joint epoxy repair?
by stoneyboy » Tue Feb 01, 2022 11:13 pm
Hi fhkhf,
You haven’t got a chance of success with an epoxy repair. Re-welding the joints are the only way to success.
It is currently Mon Dec 02, 2024 11:31 am
