Grid switch that controls fan but there is only L in and L out
Tudordoc
by Tudordoc » Wed Feb 02, 2022 11:43 am
I have a similar question. I have a grid switch that controls a fan. There is only L in and L out. I bought a DP grid swtich that includes a neon indicator and of course the neon does not light when the fan is turned on.
Could I join L1 to N1 and L2 to N2 so that current flows through N1 to N2 when I turn the fan on?
Or is this too simplistic???
THanks
Re: Grid switch that controls fan but there is only L in and L out
by Mr White » Wed Feb 02, 2022 7:07 pm
It will not work.
In order for anything to work you need a live (or switched live) AND neutral.
You have not mentioned if there is a neutral at the switch. (A Single Pole switch does NOT require a neutral.)
I often wonder, does the OP ever pop back to see if they have a reply?
It is currently Sun Jan 26, 2025 8:08 am
