Help - Changed from Ceiling Rose to wago box - lights permantly on
iandb0812
by iandb0812 » Sat Feb 05, 2022 3:46 pm
Hi All,
Replacing a standard pendant light fitting with ceiling rose and am using a wago box in loft for the new wiring of the LED lights being fitted.
This is a 2 light room with a single switch and ceiling rose wired like the below link.
https://drive.google.com/file/d/15Sqz-W ... sp=sharing
In the new wiring I've put the 2 lives together and the 2 neutrals together and then I have the 2 separate L & N wires down to the new fittings.
With breaker back on, both lights permanently on and when I try the switch it has tripped out
Re: Help - Changed from Ceiling Rose to wago box - lights permantly on
by Mr White » Sat Feb 05, 2022 3:54 pm
You have wired everything in parallel. When you operate the switch you are putting a dead short across the supply.
The picture you have is on google drive, you should reduce it's file size and host it here on the forum for all to see.
You have done the same thing that "boz" did, so the solution is the same for you as it was him. His post is a few below yours.
iandb0812
by iandb0812 » Sat Feb 05, 2022 3:58 pm
OK, thanks.
How should this be connected in the wago box?
iandb0812
by iandb0812 » Sat Feb 05, 2022 4:37 pm
Mr White wrote:You have wired everything in parallel. When you operate the switch you are putting a dead short across the supply.
Hi Mr White
Many thanks for your time and reply, greatly appreciated. Have read the post mentioned and will be re-visiting this tomorrow.
iandb0812
by iandb0812 » Sun Feb 06, 2022 3:35 pm
Issue resolved.
Many thanks Mr white, greatly appreciated
It is currently Thu Nov 28, 2024 2:34 pm
