Pull cord switch replacement for Bristan 8.5KW shower
Umustbjoking
by Umustbjoking » Mon Feb 07, 2022 1:17 pm
Hello,
I'm trying to replace the switch for the shower I'm not sure what to buy. Can I pick any pull cord switch from Screwfix?
It is a Bristan 8.5KW electric shower
Will this 45 amp be ok?
https://www.screwfix.com/p/british-general-45a-1-way-pull-cord-switch-white-with-neon/65167
Re: Pull cord switch replacement for Bristan 8.5KW shower
by Mr White » Mon Feb 07, 2022 7:26 pm
Yes, that switch will be ok. You may also find some burnt cable, when you take the existing switch down, if you have, you will have to remove the burnt/charred part.
It is currently Fri Jan 10, 2025 8:16 am
