How long do I drain back boiler for?
Steve1962
by Steve1962 » Thu Feb 10, 2022 4:35 pm
Hi newbie on here, need some advice please, I'm wanting to replace my fortic cylinder which is heated via back boiler coal fire and immersion heater, how long do I drain back boiler before the cylinder heating coil empties so I can take Flow and return pipes off and drain the cylinder, TIA
Re: How long do I drain back boiler for?
by stoneyboy » Fri Feb 11, 2022 9:58 pm
Hi steve1962,
We can’t tell you - drain the system until you think the coil will be empty, tentatively undo the bottom coil joint and if water comes out you have not drained enough out of the system.
Steve1962
by Steve1962 » Sat Feb 12, 2022 1:23 pm
Hi thank you for that I'll do that and see, much appreciated for you reply
