Washing machine replacement - do I need to block off hot water supply pipe
shalebing
by shalebing » Sat Mar 05, 2022 2:48 pm
I am having a new washing machine delivered next week to replace my old one which has both a hot and cold supply and I am assuming the new machine will require a cold supply only thereby making the hot feed redundant. Both supply pipes are fitted with on/off valves but I wanted to know if it is sufficient to simply turn off the tap on the hot valve or do I need to blank it off with something as well. Maybe I'm unduly concerned but I'd hate for it to spring a leak in the future.
Re: Washing machine replacement - do I need to block off hot water supply pipe
by stoneyboy » Mon Mar 07, 2022 10:07 pm
Hi shalebing,
Suggest you fit a 3/4” BSP cap just in case the lever gets knocked or more likely, the ball valve leaks.
shalebing
by shalebing » Tue Mar 08, 2022 11:44 am
Many thanks for your reply. That puts my mind at rest so I will get one of these blanking plugs as a precaution.
It is currently Wed Nov 27, 2024 6:26 am
